scipper77
Thread starter- Joined
- Sep 30, 2008
- 2,106
Took out my 12'er the other day with my '62 Evinrude Fisherman (5.5 horse). Coming back in the motor started to lose power. By the time I made it back to the launch full throttle was giving me slightly more than idle speed. Hmmmmm??
Got the boat home and checked for spark, and compression. Spark was present, and compression was 72 on both cylinders. Not great but even on both. I checked the coils (look like new ones), point gap, removed and cleaned the fuel filter with compressed air. I taped a few spots on the wires where the jackets were rubbing on things with silicone electrical tape (greatest stuff in the world). I even took the needles out of the carb and went through the carb setup procedure.
After all of this the motor started right up and reved fine in the bucket. So today I took it out. The boat started fine but still would barely go faster than idle speed when in gear. Discouraged I went to the marina next to where I launch. There was an old timer there who I happen to know is a magician with these old OMC's. I asked him if he had any carb kits in stock thinking my problem was fuel related. He walked up to my boat and within 10 seconds diagnosed my problem as a bad head gasket. He just pulled the rope once and knew.
So $11 dollars and 1.5 hours later I had the boat back in the water. That "Old Timer" saved this rookie a carb overhaul and who knows what else before I would have figured out what took him 10 seconds (no exaggeration 10 seconds). A big thank you to Bill at Meyers Marina.
