Hello to everyone and thanks in advance about any help given.
I have been reading the forums from before I bought my boat but I still feel like I do not know anything.
I bought my first boat a little over a month ago. I think it is a good starter boat.
It is a 1979 Sea Sprite (fiberglass Tri-hull) with a 1975 70hp Johnson. I bought the boat motor and trailer for $400.
When I bought the boat it had been sitting for about 2 years and I am not sure if it was winterized, and I was not able to test fire the motor.
Here are some things that I have done to the boat after getting it home.
Changed oil in lower unit
Changed spark plugs
removed the old gas from tanks
replaced the gas line and primer bulb
replaced the stereo
Put on a new prop
Replaced the battery
General Clean up of boat(it had moss growing inside the boat)
I want to make sure that I am not causing any damage to my boat.
The first time I put the boat in the water after doing all the above work at WOT I was going 10 mph(not planing) and after a couple of minutes it would get up on a plane and the speed maxed out at 18 MPH.
The engine Idles just fine and sounds like it is running right(so several other people have said).
With suggestion of a friend I put the old prop back on because he thought that could be the reason behind it. (it bought the other prop used and I do not know what the pitch is of either of them)
With the old prop the boat pops up on a plane fast and the speed at WOT is 24MPH.
Currently I have the old prop being rebuilt, and I am wondering if this boat should go faster than 24MPH?
If it is suppose to what could still be wrong with it?
Would it hurt the boat to keep running it the way it is?
Changed spark plugs
replaced the stereo
Put on a new prop
