I Have to Fill a Below Waterline Hole
hallsy2two
Hello Friends,
I have to fill a hole that is below the water line that was used for a bolt for a small swim platform. It is only about a quarter inch diameter. What is the best method? I have seen an epoxy that looks interesting, but it seems like a self tapping screw with a rubber washer would work equally fine? Any tips would be great. Thanks.
seedlings
Re: I Have to Fill a Below Waterline Hole
This is what you're looking for. Local Home Depot sells the 3M 5200 10oz gun tube and a 3oz? small tube.
http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
CHAD
*EDIT: read further - this is not the correct method
sublauxation
I forgot to fill on small hole after my transom rebuild last year. I reached under the water with the 5200, dabbed some on the hole and that was it. Held all summer.
Maybe wouldn't be a bad idea to use 5200 with the bolt and washer but probably not needed.
emoney
+1 on the MarineTex. I used it to fill 4 screw holes in the bottom of my hull. No more leaks and very easy to work with.
dingbat
5200 is sealing adhesive. It gets hard over time and looses its sealing properties. Improper use is probably responsible for more transom replacements/ repairs than I care to think about.
Do yourself a favor and do it right. Drill out the hole big enough to fit a small wood dowel. Coat the dowel and inside of the hole with epoxy and tap the dowel into the hole. Make sure the dowel is an 1/8? or so below the surface of the gel coat. When dry, fill the rest of the hole with gel coat or Marine-Tex. Sand and polish as required.
You will end up with a permanent repair that will not have the next owner looking at the cost of replacing the transom due to your negligence.
shrew
Ditto on dingbats answer. the name might say dingbat, but it certainly doesn't seem to apply. The repair section should have a lot of good info. too. Resin and layers of fiberglass, with a coat of gelcoat would also be a good answer. Marinetex is also a popular solution.
However, using 5200, lifeseal or lifecaulk are probably not the best solutions. That is ok for sealing a bolt, but not an empty bolt hole.
