i have a prop qustion,,,and im new here
little2rude
i run a 1966 johnson 20h----model-fd20
?? first number is size and second is pitch rite ?
need a new one for my motor,it currently has a 9x9
they offer 9x9..9x91/4,,,9x10,,,9x11 the 9x9 just isnt what it should be,,,,im not looking for qwiker hole shot or nothing but will the higher number pitch give me a little more umf,power,speed,
i mean its only a 20h,,just lookin for a little more.
what ya all think ??
steelespike
Re: i have a prop qustion,,,and im new here
Welcome ,please read the stickies at the top of the page and get us as much info as possible.
I can tell you we will be looking for rpm and speed. A tinytach for rpm will work and
a gps for speed.In the mean time as much info as possible.
pootnic
Power...Speed.
Two different things:
Power=lower pitch,normally quicker planing,higher rpm...maybe slower speed(depends;rpm)
Speed=higher pitch,normally alittle slower planing,lower rpm
A higher pitch might give you more speed,if you have the proper rpms.
Not running your outboard at the proper rpms will hurt it,weither it's higher or lower,rpm.
Think of it like a bicycle.
Your in 1st gear(9 pitch) going up a gradual hill...no problem(good rpm).
Then throw it in a higher gear,say 5th(11 pitch)...it's harder on your legs/heart(motor),might not be able to do it for along time(to low rpm WOT).
Probably just as easy to read the above post.
little2rude
Power...Speed.
thank you vary much for your advice,,understand a little better now,,,,as far as the above post,i new to this fourm,ive read alot of info on here
before i posted a question !!!!!! not quite sure what stickys are,,,,(for give me),,, im still gonna ask questions
steelespike
The first 3 lines of the prop forum are Stickys.There are often stickys at the top of a forum
to help visitors understand better what they need to know about posting for the best results.
