i have a 1994 mercury 150 xri
Lucky Paul
well can any one help me out. with this 1994 mercury xri I have two fuel injectors that will not fire on the same side
Dukedog
how do ya know they aren't "firing"?
3 reasons.. ecu, injector harness (internal) or injector itself....
ecu fires in pairs...same signal fires both.. 3 & 4, 5 & 6, 1 & 2.. so 2 on tha same side pretty much eliminates tha ecu..
Lucky Paul
so where I do I look at fixing this the boat dealer is just changing parts on me, thank you,
Lucky Paul
well I took them off the boat motor and put 9 volt battery on them and they spray. both worked
Lucky Paul
well I look at the wiring and it all looks good, it all looks like the ecu could be bad. it is all good on timimg just wont fire all of the time, when I go on plane it runs like it floods out and wont go and than it goes and than it does it again,
Faztbullet
Sounds like your loosing the high speed side of stator on one bank or switchbox failing....
Lucky Paul
just two injectors on the same side the bottom two they said it is the e c u. we tried the 9 volt batteries they fire so what is bad. I just wish I can talk to some one one a phone
Faztbullet
Swap the injector to different cylinders, if they fire in those pkace the harness or ECU has a problem. If this is the case PM me ....
