I have a 1987 mercury classic 45 hp with problems.
dodgetruck51
My engine will always idle really fast and will not reach top rpms. HELP PLEASE. Also I have rebuilt both carbs,fuel pump and replaced the fuel tank and all hoses and connections, compression is 115 on all cylinders, plugs are good
roscoe
Welcome to iboats.
Carbs set to factory starting points?
Complete link n sync after the carbs were done?
Drop the lower unit and check exhaust tube for blockage.------And link & sink means you need to synchronize carburetor opening with ignition advance.
dodgetruck51
I finally figured out neither carb have a idle tube in it. Will a motor run correct without them?
