f_inscreenname
- Aug 23, 2001
- 2,591
Have a 19'1972 John Allmand/Super Nova. When I bought it 2 years ago I thought it would be a simple swap out of motors and a paint job. Boy I was wrong. It came with a 318 mopar and a volvo 270 outdrive. Two winters ago I built a bad ass 360 ci to put in it. Then spent 6 months looking for a fly-wheel that would work with it (it also cost $800.00 + the cost of having a hi-pro shop to rebalance it). There goes one summer. Soo I spent all winter making sure everything was just right. A couple of weeks I installed my motor with the golden flywheel and everything was fine till I bolted up my outdrive. Sitting on the trailer when you turn the outdrivr all the way to on side or the other it rattels,loud, inside the bellhousing. I then pulled the outdrive and motor. Installed new U-joints in the outdrive and had the bell housing and drive shaft rebuilt. I also replaced the pilot bearing In the crank. I spent a hour grinding it down to fit inside the hole (there is only 1 bearing for all for small blocks mopars and it didnt fit,I had to cut it down by 2/3's the thickness). Got it all put back together and still have the same rattel.It even seems a little worse. I am at a lose to what to do next. This B/S sucks! I have always had mercrusier and chevy/fords and never had this s*#t. What do I do next? <br />It has 50 gallons of gas in it(another thing just bought at 1.57 a gallon) and a road flare sitting right there on my work bench. Humm.......<br /><br />04/30/2002<br /> It was time to go break something. Or at least that is what I thought. Went down to the boat ramp and droped it in. Under load it dose not make the banging noise (tin spoon hitting a tin plate) but when turning L and R in gear you could feel it vibrate in the hull (rember its only 19'). I am happy to report that nothing broke and man was it fast. My pattel wheel speedometer was up to a solid 60 mph at one point. It is a new motor so I didnt want to do that for long. As you can see I have a lot of HP so I need it right,with no vibritions.<br /> I think the right course now is pull the motor and have a pilot bearing made (No home made stuff) for the hole in th e crank. Come to find out my crank was never cut for one so I have to have one custom made. I think also I will replace the vibration damper just in case the springs are a little weak. Any thoughts?
