- Jul 18, 2011
- 19,643
. . . boat seat that is . . .
As I was cleaning and bleaching the cockpit and compartments yesterday, I looked under the rear seat and noticed a crack in the fiberglass base of one of the rear seats. This particular seat is a cantilever base and is part of the rear "U" shape seating.
Here is the general location of the problem and a closeup of the crack on the base of the seat. . .
Whatever the weight capacity of the seat is, obviously it has been exceeded at some point.
I decided to fix it by adding some more fiberglass on both sides of the base. Here is a picture of the seat removed . . .
The entire seat assembly looks quite complicated to remove, so I would have to patch the cracked area as best I could from inside & outside the fiberglass base, and what was accessible.
I ground into the gelcoat and roughed up the inside area as well. Here is a picture of the outside area after fiberglassing. I used 2 layers of 1708 on both sides of the damage area with VE resin. Hopefully, it provide enough strength.
Since I was not able to disassemble the seat to expose the area further, I had to make do by masking the seat back.
- - Continued on the next post - -
