I have a 2007 200 h.p. Evinrude ETEC saltwater outboard engine and I can't turn off after I start it. When turning the key to the first position the power is turned on to the computer and fuel pump. Then turning it to the start position the motor turns on. Once the motor is running I can't turn the engine off by turning the ignition off, turning the emergency shutoff off, disconnecting the battery, pulled the ignition wires out of the ignition switch, and eventually I had to pull the spark plug wires to kill the engine. Is their something charging the system once the motor is running? Could it be a relay? Or could it be that the emergency kill switch is not properly grounded?
