Pontoon rebuild.
New 24’ cables.
Can’t seem to get throttle set properly based on everything I’ve read.
Adjustment says link and sync. Butterflies closed at neutral. Done.
Burtterflies horizontal at WOT. This is where I have an issue. Nothing I do seems to get them horizontal. Not even close really.
Also the engine seems to remain at high RPM at idle.
Timer Base has been removed and cleaned. New lithium grease applied. I have ensured that no wires are catching it.
It doesn’t seem as if there is enough travel in the cam to open the carburetors all the way up. I am all ears to any advice. I can’t seem to get it figured out.
Thanks.
New 24’ cables.
Thanks.
