I can not get my shift rod lined up
brandon25
I have a 1975 85hp mercury. I had to get a new lower unit because mine froze and cracked the housing. I bought a new one and now I can not get the shift rod lined up.
turtles11756
Re: I can not get my shift rod lined up
follow the shift shaft down from the top of motor you can hold it in place or move it around a bit down by the reverse lock rod to line it up .when it's right it will come together with hand hand pressure. grease the splines
turtles11756
the reverse lock cam also must be in the right position
brandon25
i finally got it lined up, it took me about an hour. my motor does not have the reverse lock cam, it has a tilt and trim.
