- Apr 17, 2002
- 71,423
Re: I am dissapointed
Right Now is not the Time, But I Promise, I Will do a FAQ........<br /><br />Walt, No Disrespect, But,<br /> "Distributors and distributor caps must not have any vents on them. " <br />Not Quite........
<br />All Distributors Must be Vented........<br />Without vents the Ionized Gases, from all the sparks, couldn't escape.........And the dist. will cease to function.....<br />But, Marine Dist. vents Are Sheilded, ei; with the use of Screens,+ Elbows(Sparks Can't flash Around Corners)<br />Pretty much like the Marine Alt., There's Alot of sparking going on in an Alt., or a Starter.....<br />Alt.s are shielded by Screens.....<br />Starters have a Shielding Plate, added between the starter motor,+ the bendix drive.....<br /><br />DJ, You're No Doubt Right about many of these various engines....<br />But, In My Experince, GM motors from the early 80s to present, Are Production Pick-up engines..... Brass freeze-plugs, Maybe a different cam(thou I Doubt it).....<br />Still just a Cast-Piston, 2 bolt main block(No difference in the Metalurgy)....<br /><br />The Absolute Best Reference books on the market, are the 1s by Dennis Moore.....<br />"Small-Block Chevy Marine Performance",+<br />"Big-Block Chevy Marine Performance"<br />He debunks All the Myths..........
