I am completely lost on this one.
smitty2750
I have an 1989 Evinrude 110. I have had it for about 3 months now and for the most part it has been a really good motor. About 3 weeks ago I put it in the lake and got a little nervous when it took me a couple min. to get it to start. It started and i took off across the lake running pretty much wide open for about 15 min until i reached my destination. I fished there for about an hour then same thing. Took me a min to get it started. this never stops. it has only gotten worst. When i first try to start it, its really difficult. Once started it idles fine and runs fine. When hooked to muffs at home of course it starts fine. I'm assuming because there is no back pressure from the exhaust being underwater. Now let me throw this in there. If I start my boat then turn it off. As long as I start it again within about 15 min it will fire right back up. if i wait to long i will be stuck trying to get it to start. The carbs were cleaned by the way when this first started bc i thought that was the problem but obviously not. And while running across the water it doesn't miss or anything, nice solid smooth ride. Any ideas?
Honorary Supreme Mariner
Are you pushing the key in while cranking it over to start ?------Have you done a compression test on this motor ?
smitty2750
no i do not push the key in to choke it. I have never had to choke it to start it. I did try that but i think i flooded it and made matters worst. after that i just start it without. I can smell fuel after trying over and over to start it. once it starts i get blue smoke for about 5 seconds then smokes gone and runs fine. I guess it acts like its flooding itself. but if it was getting to much fuel it would seem to me like it would bog down and run terrible. I have not ran a compression test on this motor. I assumed compression was fine. However i do plan on buying a compression tester tomorrow and testing all cylinders just to be sure.
ob
Do you mix 50:1 or have the VRO in operation? By ruling out the carburetors as the cause, I assume you are sure that all of the necessary adjustments have been made, all of the fixed orifices are clean and clear, and the linkage has all been synchronized? If so, a compression test ,as mentioned above is a good next move.
oldboat1
^^+1. We're taking your word for it re. carbs....
Cranking speed might also be an issue. Need a fully charged battery, clean connections, good operating starter.
EchoNovember
Really dumb question here as you didn't mention it. Are you repriming it every time? It could just need to have the bulb squeezed a few times to get it primed, otherwise the fuel pump has to work to pull that initial fuel charge in. If your carb bowls are leaking, then there would be a need to reprime it every single time to get it going. It does sound like this is not the issue, though.
It could also be fouled plugs, bad compression, etc.
Joe Reeves
Although you may be overlooking something in cleaning/rebuilding the carburetors... that area is not anything I'd be looking into right now as you state that once the engine starts, it runs fine... my reasoning is that carburetors do not come and go... if they're bad, they stay that way.
The proper starting method of a cold engine is to.... Pump the fuel primer bulb up hard.... Apply a slight bit of throttle..... Turn the key to the START position and PUSH the key in at the same time to engage the Fuel Primer Solenoid (There is NO choke on that engine!).
You state that the engine starts fine on a flushette BUT not in the water... and you mention exhaust back pressure when in the water probably being the cause. Well, you've sort of hit on the cause but didn't think it further through enough. The exhaust back pressure results in having the engine crank over slower and that affects the ignition system.
That engine must crank over at least 300 rpm in order for the stator to supply the needed "AC" voltage to the powerpack capacitor (approximately 300v AC) which is needed to energize the powerpack/ignition/spark.
Remove, clean, all terminals of the wires and cables that pertain to the starting system, including the battery, solenoid, starter, ground cable at the powerhead, etc.... also clean the components they attach to. A tight but dirty cable will result in a "DC" voltage drop that will cause the cranking power to drop.
Also.... carefully inspect the stator under the flywheel. The stator is the beginning of both the charging and ignition system. Look for cracks and any portion of it to be dripping a sticky looking substance down on the powerhead area.
(Fuel Primer Solenoid Function)
(J. Reeves)
The RED lever...... The normal operating/running position is to have that red lever positioned over top of the solenoid and aimed at the other end of the solenoid, gently turned to its stop. This is the normal/automatic mode position. Pushing the key in opens the valve within the solenoid allowing fuel to pa$$ thru it in order to prime and start the engine. Looking upon this solenoid as a electric choke results in a better understanding of it.
Having that red lever turned in the opposite direction, facing away from the solenoid, allows fuel to flow thru it to the crankcase area. One would only turn the red lever to this position in a case where the battery might go dead and the engine had to be started via the rope pull method. Look upon putting the red lever in this position as moving a choke lever on a choke equipped engine to the full closed position. Either one would supply fuel to the crankcase/engine for starting purposes BUT if left in that position while running would flood the engine.
The later model primer solenoids are equipped with a schrader valve, used for attaching a pressurized can of fogging oil etc, available at your local dealership with complete instructions.
Pumping the fuel primer bulb up hard fills the carburetor float chambers of course, but that process also applies fuel pressure to the primer solenoid.
The two small hoses leading from the primer solenoid branch off via tees to each fuel manifold section that would feed fuel to the individual cylinders.
Pushing the key in activates the primer solenoid to allow fuel to flow thru it to the intake manifold pa$$ageways. Cranking the engine over causes the fuel pump to engage which in turn sends fuel pulses to the primer solenoid via the 3/8" fuel hose.
Some engines incorporates the "Fast Start" feature which automatically advances the spark electronically so no advance of the throttle is required for starting.
Engines that do not have the "Fast Start" feature will be required to have the throttle advanced slightly.
Starting procedure: pump fuel bulb up hard, crank engine and push the key in at the same time. When the engine fires/starts, release the key so that it falls back to the run position.
Bottom line..... Look upon the primer solenoid as an electric choke.
Let us know what you find.
interalian
An easy test for votage drop on battery cables:
1) Set your multimeter to DC volts and attach one multimeter lead to battery negative (-), and the other to a shiny ground on the motor.
2) Crank motor while watching the meter. If you see more than a half volt reading, you have a problem with the cable or a termination.
3) Attach one multimeter lead to battery positive (+) and the other to the main terminal on the starter and repeat step 2. This test may read higher as the solenoid switch may cause higher resistance.
oldboat1
I would try to keep it simple at this point -- shine up all connections (sandpaper, file, etc.), charge the battery -- get it checked out if appropriate, make sure proper starting procedure is understood. The only test I would make is a compression test.
smitty2750
Thank you guys for the responses, I got a little behind today and was not able to do the compression test. I will let you know how that turns out when i get to it, hopefully tomorrow. As for the primer bulb, i do squeeze it until firm. Someone mentioned the primer solenoid red dial on top being turned toward the back of the solenoid. I am not sure if it is all the way turned or not or which way it is facing. I'm actually writing these recommendations down on a piece of paper and plan on going through all of them. I will do compression, then use my meter and check the voltage. if not so good ill clean all connections, battery itself is good, i replaced it about 3 months ago. I have a trickle charger that i use to keep it maintained as well. Also to answer one of the questions ask, i do not have to mix the oil i have a VRO that is working. So i know it's not me with the mixture. Will talk to you guys tomorrow with some results on what I find. Thank you again for all the replies and help.
interalian
The lever on the primer is supposed to be inline with the body of the primer housing for normal operation. You'll probably have a sticker under the cowl showing this.
smitty2750
So the primer was in the correct position. looked at that last night. It started raining so not a whole lot i can do right now. I do not have a garage, just keep the boat cover on it.
smitty2750
No Title
I put a little red circle in the picture with the whole motor, the other picture is the inside of the little red circle. It has a little puddle of oil. Not sure where that is coming from, could this be causing my problem? I ran a compression test today, had 101 & 102 on the right side. had 100 & 99 on the left. Does this sound ok to you guys? I was gonna check the electrical with my meter but once i seen the oil and noticed it must be dripping from higher up because it is also on the terminal for the starter i just put my meter up. Ill never get an accurate reading with oil on it. As for now, my next step will be to find this oil leak (no idea where to ever start) and get it fixed and all the oil on the motor cleaned up. After compression test I basically stopped to write this. Should I go start the motor on muffs and let it warm up then run another compression test. ( remember it runs good on muff and in water, starting it in water is the hard thing, starting on muff is piece of cake.)
ob
A little two cycle oil accumulation under the intake silencer cover is normal for many two strokes. I wouldn't sweat that too much. What I would do is read Joe Reeves last post thoroughly and pay particular attention to inspecting the condition of the stator under the flywheel , as it sounds like you may very well be chasing an ignition issue. I'd also highly recommend a spark test at cranking speed using an adjustable gap tester set to 7/16" and look for a crisp blue spark that "snaps" across the gap. And be certain that you have a good fully charged battery when testing.
interalian
The 'oil leak' may be a perished or disconnected drain tube from the silencer. It goes to the bottom of the motor under the lower carb. It could also be from a bad gasket between the silencer cover (plastic) and the silencer housing (aluminum). A little oil there isn't unusual, especially if you tilt it with the carbs full of fuel. Oil on an electrical terminal won't affect connection for your testing.
smitty2750
Thank you guys, will check the stator tomorrow. Ill take pictures if im unsure of anything. Ill keep a check on this forum for any other replies. Thanks again. Will post condition of stator tomorrow.
