I am Clueless about my Props?
phelpss
I have a 1987 WellCraft 192 American
With a Mercruiser AlphaOne
Model MCM140
Serial # A676633
We are refurbing the boat, and took it out on the water with some rough water over the weekend and knicked up the prop when we were trailering.
My questions:
1. if one of the blades are alittle knicked up do i need to replace the prop?
2. Any idea what size or make/model prop i need? the current one is nice and old and i took it off and there is no way to see the pitch or anything off of this one?
Help boys?
junior1113
Re: I am Clueless about my Props?
repair or replace right away could cause a vibration on propshaft and damage other in ternal parts. there has to be some #'s on that prop. what was wot rpm and speed with it. hard to tell what prop u need with out knowing what this motor is pushing. what kind of boat? weight? length? gear ratio?
theres no one specific prop for any given engine it depends on what pitch your motor can spin while still being within recomended wot rpm range.
example: your motor on a 16' boat would need like a 23- 25" pitch
your motor on a 21' boat would need like a 17- 19" pitch
phelpss
ok good to know about the prop screwing up internal parts of the motor.
Well its a 20ft WellCraft with a Cuddy. Just got it so not sure of all the details of everything.
Where should i look for details on stuff to help guide me?
junior1113
i'd say a 3 blade 17 pitch should do it. you need wot rpms to be 4200-4600
steelespike
Look for numbers on the prop under the prop nut.A prop shop can repair your prop,if no numbers they can measure it for you.
Get her repaired give us the prop size,and your max rpm and speed with your typical load.
phelpss
I looked under the hub, there is nothing, looks like it is corroded off. I guess i will take it to a prop shop and try and get them to measure it for me or something. thanks guys.
captkevin
Find a good prop shop & bring them what you have for repair. They can help from there. If no good ones near by a lot of people use midwestpropeller.com
