The fitting on my tilt cylinder broke so I replaced it, filled the pump back up with oil and all worked fine! I was raising and lowering the motor a few times to bleed out any air (according to my repair manual) then all of the sudden the pump motor just stopped working! when I hit the switch i can hear a click that sounds like it is coming from the pump but thats all! anyone have any ideas where I should start on trying to fix this?? Thanx!
