hydro electric switch
d.g913
this post is for JT72,i have the same problems with my neutral,forward,reverse switch,i would really like to replace it as you did with a three position toggle switch,to do this i need to know how to wire the toggle in place of the oem switch,any help will be appreciated more than you can imagine,i have had to replace this thing 3 times in as many years,and at 85.00 a peice it is quickly getting old
Hooty
Re: hydro electric switch
This is part of an old post. Hope it helps.<br /><br />c/6<br />Hooty<br /><br /> In neutral, you need 12v to the "Green" wire. <br />In reverse, you need 12v to both wires, the "Green" one and the "Blue" one. <br />In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear) <br /><br />To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed. <br /><br />This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).<br /><br />With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
Joe Reeves
What you are asking can and has been done but you must keep in mind that wiring a toggle switch in such a manner allows one to accidently shift from forward to reverse at full throttle. This could and probably has resulted in injuries to boaters, not to mention the mechanical damage aspect.<br /><br />For the above reason, I strongly suggest that the toggle switch have a hinged hard case cover installed over it so that the toggle is never thrown accidentally.<br /><br />Now, with a single pole double throw toggle switch installed so the the "Green" wire connection is facing up or away from you, make the following connections to the terminals on the back of the toggle switch.<br /><br />......O Green Wire<br /><br />......O 12 volt Supply<br /><br />......O Blue Wire<br /><br />Now, between the Green wire and Blue wire terminal on the toggle switch, connect a diode capable of handling 12 volts (available at Radio Shack etc). Be sure to install the diode so that the voltage will travel from the Blue wire connection to the Green wire connection only...... and not vice versa!<br /><br />Now, if you have installed the switch as above, with the toggle pulled all the way back (towards yourself), contact will be made between the 12v supply and the Green connection. This puts the unit in Neutral. The diode prevents any voltage from gaining access to the Blue connection.<br /><br />Pushing the toggle lever to the middle position results in no voltage being supplied to either wire. This results in the spring loaded clutch shifter dog in the lower unit throwing the unit into forward gear.<br /><br />Pushing the toggle switch lever all the way to the front position will have the center 12 volt supply connected to the Blue wire connection, and due to the diode, that 12 volt supply will also be supplied to the Green wire. This results in having the unit in reverse gear
Hooty
Joe makes an excelent point. Aircraft supply houses handle spring loaded toggle switch covers. I have one on my start-in-gear switch.<br /><br />c/6<br />Hooty
