1971invader
Thread starter- Joined
- Jan 10, 2017
- 7
Hey guys I am not the kind to post on forums I usually search hard till I find a solution but I'm out of options here... not familiar with this setup other than what I've read .... with that being said my engine doesn't fully engage reverse it only makes what I'm assuming is a partial engagement and makes a clicking noise and doesn't really go anywhere but the prop does spin in every direction neutral and forward works perfectly but reverse makes the noise and has no power.... I just got the boat it has been sitting since 2004 and I got it running and took it out before I took it out though I change the lower unit fluid and it was like molasses I don't know if they tried to put grease in it or what but I replaced it with ATF if it was a cable driven design I would assume it was out of adjustment but with this situation it's obviously not.... any help is appreciated thanks
1971 85hp Johnson
1971 85hp Johnson
