Hydro electric drive stuck in forward!?!
Buckwild12484
Ok, I bought an older boat this year in hopes of fixing it up and taking it out. It has a 65 johnson Hydro electric motor. I took the boat with my father in law to the river just to see if in ran good. It cranked, idled, put through the gears no problem. Took it home and it sat in my yard a few months. Well today took it down the road to a guy at his boat shop, got it where it would run and it's stuck in forward. We looked over everything to think of and came up short. After getting home I got to thinking that the only thing that changed in that time was that my father in law unscrewed the lower unit to check the oil and let out a little handful of oil. I read through some posts earlier saying that there are solenoids in the lower unit that are controlled by oil pressure I suppose. So I'm thinking of adding oil back in to see of that will work. Is there anything else I need to check? Thanks in advance.
Honorary Supreme Mariner
Lower unit must be full of type-C gear oil.-----Motor must be running in order for oil pressure to shift it.
Tim Frank
Doesn't sound like you would have known how full the LU was.
Top it back up and see where you are.
F_R
You need to understand how it works. It actually shifts by hydraulic (oil) pressure. The gear lube doubles as the hydraulic oil. For some reason, everybody seems to want to blame the solenoids (usually not the problem). The electric part and solenoids only direct the oil flow via a couple of valves. Keep in mind that it is extremely important that the oil be CLEAN and uncontaminated, and the correct oil must be used. Water and/or microscopic dirt or grit in the oil is the worst enemy. That's why you are supposed to change the oil as a regular maintenance item.
The shift defaults to forward gear as a get-home safety feature, so everything from the shift switch in the remote control, and on back to the oil must be working, and it must be running.
