dominic colvile
Thread starter- Joined
- Dec 20, 2008
- 6
Hi guys,
Wander if anyone has had any ideas with this one.
I have a hynautic hydraulic steering system on a 175hp mariner. when going slow steering works easily when going fast turning right is fine but when you try to turn left you keep turning the wheel and little happens as though the oil is pushing past the ram seals or possilby the valve is'nt shutting properly there are no leaks, could it need bleeding. if so what oil do they use and does have anyone have a bleed sequence.
it has been sat for a while and not used.
cheers dom
cheers dom
