Re: Hydraulic Lifters Bleed Down Time
I can understand 3.5psi as a fuel pressure although I would rather see 5-7psi. I've seen then down as low as 2.5, but 1.5psi sounds low, even if its on your good engine. I question your gauge, and where you are tapping into the system. Is there a fuel bypass return on the system?<br />As clanton asks, what is the compression? Again, all the variables can be identified by comparing the vacuum from one engine to another. We need numbers and consistancy. <br />>Did you "power time" the engine or use a timing light? A dampner pulley (harmonic balancer) can slip and skew your timing marks. Either establish piston TDC manually and check the marks, or power-time the engine(preferred).<br /><br />What is a dizy?
