Hurricane Fuel Sending Unit
golfinw71
Please forgive me if this has already been addressed else where on the forum. I recently just purchased a 1999 hurricane 198 in which the fuel gauge pegs 'empty' when you turn the key on. My steps thus far:
Power is getting to gauge and sending unit
Using a test light, with the ground of the light attached to the battery ground and touching both the Red and Black wires, both show a completed circuit.
tested the resistance between the red wire and grounding (with the black wire detached) and got a reading of 45-50 (the tank is practically full)
With all wires connected, and using the test light. both connections have a completed circuit with the ground light attached to the batt negative.
If I ground the fuel sending unit directly to the battery, the gauge reads 'full'
what baffles me is with the green/black wire when disconnected and using a VM, is showing 12+ volts
Is this correct? I thought this was a ground/bonding wire that, when the VM is connected to the negative of the battery and connected to the green/black wire shouldn't show a reading.
How do I make sure the unit is wired correctly before I buy a new sending unit? thanks for any help!!Fuel Sending Unit.jpg
foodfisher
Re: Hurricane Fuel Sending Unit
The members in the electric, electronics forum will help you out.
Campylobacter
I have hurricane 195, and the gauge has not read properly from day 1. If the bow is up it reads full, bow down it reads empty. I just keep track of how long its been since I gassed it up.
I know this doesn't really help :cold:
How do I make sure the unit is wired correctly before I buy a new sending unit? thanks for any help!!View attachment 228060
Ayuh,..... Welcome Aboard,.... That's not right, green is bonding, 'n black is ground, they're both common with the battery Negative(-),...
'n That, I don't understand,... The red should show 12v, 'n the black should show Ground,...
MH Hawker
A fast sending unit test is to jump the red at the sending unit to the black, dont connect it just bump it as a connection. the fuel gage should go to a full tank reading, the sending unit reads by resistance and by jumping it has none and it reads full.
golfinw71
Thanks Bondo, and everyone else for the suggestions, I will try them this evening and see what I can figure out I'll keep you posted!
