Hummingbird 560 constantly shows fish in deep water
joelkoepfler111
Hey guys,
First time post on here hoping to gather some information on an odd thing that ive noticed on my finder.
When fishing for lake trout in deep Canadian lakes (80-100) my finder consistenly shows large fish returns between 8-14 feet from the surface.
Other than the possibility that I have lunkers all sitting under the surface during the summer (which I doubt), what could be causing this return on the sonar.
I generally keep the sensitivity at medium to low and have the surface clutter cut down.
any opinions appreciated.
Joel
robert graham
Re: Hummingbird 560 constantly shows fish in deep water
Well, mine's a Lowrance model, but it's forever showing fish at various depths that I really doubt are there...at least I'm not catching them!...I've got where I don't believe what the unit says!:)
KDAVID1
I use a 560 at the console and it does some strange things as well (shows 1ft of water) when I know it is 15ft deep--but anyway--you may want to mess with your sensitivity settings. Also not using the fish picture setting (just raw signal return) may help as well.
Rick.
I've had good luck calling Hummin Bird customer service. You might try giving them a call. Best of luck. Rick.
Huron Angler
Are you trolling with downriggers when this happens?
How deep are you fishing?
Might be some suspended walleye? Sounds like a great place to fish:D
Gibbles
The hummingbird fishfinder in my FIL's boat will do that sometimes.
One time it about got us in trouble using the depth gauge, saying we had 20ft coming into a little bay, till I saw the ground in the water...
I found it can be fixed by turning it off, then press and hold the power button until it gives a long beep.
from there it will work fine until the depth starts to look give a weird return.
Recently it stopped working, he is not planning on trying to fix it at all, just replace it this spring.
