Humminbird GPS install question
Djfan
I bought the GPS for my Humminbird 717 and don't have the post it sits on in the kit. It was factory sealed so I'm guessing they sell it separate or you have to make one?
Anyone have any ideas on what to mount it on?
It's the black post and base in the picture I'm talking about:
ajgraz
Re: Humminbird GPS install question
That GPS antenna uses a standard 1"-14 thread, so you could use any standard marine antenna mount you want, maybe something like this:
http://www.iboats.com/Shakespeare-G...7304015--**********.486255507--view_id.359304
I've got mine on a rail mount, but I can't recall where I got that from.
IIRC, you can also substitute a 3/4" NPT PVC fitting for the 1"-14 and rig up something from Home Depot ;)
mphy98
I did not use a post mount. Just mounted the base to the back of the boat. Never have had a problem with it. It works just great and without it bieing up in the air, less chance of breakage.
John_S
I would test it to see if you even need to elevate it. Most times, that is not neccessary. Mine is mounted flat to a same size diameter 1/2" thick king starboard. I have velcro on the back of the starboard. I mount mine back near the corner of the transom, relatively close to the transducer. This provides better accuracy of marking and returning to structure I want to fish. It is on velcro, such that I can remove it. It also sits perfectly in a cup holder I have back there. No issues if I run it in that, either.
