Humminbird Depth Sounder
Ranger363v
Hello. I own a near perfect one owner 1990 Ranger 363v. Problem encountered is both orignal humminbird depth sounders don't work. Both just spin around and click. I tried to send a message to humminbird but an error did not permit it to send. Are these fixable OR is there a direct replacement available?
John_S
Re: Humminbird Depth Sounder
If they are original equpment that came on a 1990 boat, then they have long expired from the "repairable" list.
It sounds like you are refering to the tilt/swivel mount. If both don't power on, I'd suspect some sort of electrical problem, wiring, fuses, connector pins, etc.
Post what models you have. User manuals should be available on HB site/
First step is to see if you have 12V at the power pin. Release head unit from tilt/swivel, and look at the connector block. The power cable is a two pin connector.
sschefer
I don't really understand the spin around part unless your talking about the low speed paddle wheel style speed sensor. That's usually just a temp and speed sensor. If the transducer is clicking it's sending but it may not be recieving a signal back. Check to see if the wiring has been spliced at some point. Maybe the HB is a replacement and whoever did it, didn't want to pull the wire to replace the ducer so they just spliced the old in. If that ends up being the case it may not be the correct ducer for the head unit.
NYBo
Welcome to iboats!:cool:
It sounds like you're describing a flasher sonar unit, like the Humminbird Super Sixty. Forget about repairing them; they don't provide a lot of info, and you can buy cheap LCD fishfinders that wll perform much better. For those who don't know what a flasher is:
