Humminbird 383C GPS/Sonar Combo
RCSConstruction
# High performance color fishfinder with GPS and built-in maps packs high-end features in compact size.
# Internal 16 channel WAAS GPS receiver with omni-directional antenna for higher performance.
# Built-in 4 nautical mile resolution UniMap of USA inland lakes, rivers and coastal areas
# Brilliant color, 320V x 240H high resolution 3.5" TFT display
# DualBeam PLUS sonar delivers wide coverage and better bottom definition
# Selectable 20? or 60? beams, or simultaneous operation
# Reliable performance from shallow to 1000 feet
# Water temperature and GPS speed included
# Tilt & swivel quick disconnect mount system or optional in-dash mount
# Click here for the 383c manual in PDF format. If you need Adobe Reader to open PDF documents, click here to get it.
# Freeze Frame instantly pause display allowing more time to see the details
# Digital Flasher View delivers real time, flasher performance
# Big performance with compact design ideal for small spaces
# Convenient tilt & swivel quick disconnect mount included
# Optional in-dash mounting easily fits consoles outfitted with a 5 1/8"H x 5 1/4"W mounting space
# Real Time Sonar instantly captures the action under the boat.
# Sonar Echo Enhancement reveals the smallest details - even your jig!
# One-Touch Zoom and Bottom Lock enhance resolution and separate fish from structure
# TruArch shows actual fish returns or choose selective Fish ID+ with target depth
# Precision 2 ?" target separation reveals close hanging fish
# X-Press Menus access the most important controls with fewer button presses
# Selectable large digital readout view for easy readability
# Microdynamic transducer slices through water for reliable readings to 70 MPH
# Fresh and saltwater options for optimal performance in any environment
# Adjustable 2x, 4x, 6x and 8x zoom levels
# Adjustable backlight for night fishing
# Fully gasketed, waterproof construction - they float!
# Assembled in the USA, One year limited warranty
This a good entry level combo?
I can't tell if I can add maps and software????
Any other recommendations in the $400-500 range?
Thanks
Chris1956
Re: Humminbird 383C GPS/Sonar Combo
I started looking for an entry level combo unit this year. I found that althought 5" display units were within my price range, I thought the screen was too small to view both functions simultaneously, and that is what I wanted to do. A 3.5" display will be much smaller, and I think virtually unusable. I recommend you look at the display yourself and see. They can be found in a lot of discount marine stores (West Marine, BoatUS). You can buy online and save a few $$.
lncovert
I have this unit (Humminbird 383c combo). It works great. I also thought the screen was going to be a little small, but it is fine for me even in split-screen view as long as you are sitting in your seat. If you are standing up at the back of the boat, then you won't be able to see the fish or the details of the GPS, but it does have a Big Digits view which displays your Depth, speed, temperature, voltage, etc. in really big digits so you can see those far away.
But...for the GPS you only need to see that sitting down in the captain's seat.
Click on my pictures below, I've got a picture of it mounted in my boat.
