A 2004 SeaRay? I'd bet not. More likely composite or engineered stringers.Wood, probably douglas fir, that is pretty common.
Rob4926, here you go, from someone who owns a 2004 Searay, very good info. For the record though wood is very common and what you'll find in most boats.My 2004 Sea Ray does not have wood stringers I believe they are composite and ‘glued’ to the fiberglass hull
look around the engine mounting points there will be 1” plugs in the side of the stringer for putting foam under the floor you can easily pull one out and see the stringer construction
If I recall mine is like a composite or glass lay up built over a foam core that is essentially the mold. The insulation is blown through two holes in the stringer to the Void space outboard of the stringer so you can get good access to how it’s constructed easily
True wood was main material used for stringers transom and deck material for many years, often nothing more than plywood tabbed in.Rob4926, here you go, from someone who owns a 2004 Searay, very good info. For the record though wood is very common and what you'll find in most boats.
Thank you for the info! That will go along way. How is the maintenance on the searay. Do you have to replace the gimbal bearings, manifold or any other parts often? I went to look at one a few days ago and the guy told me every 2 years he replacing the bearings and manifold.My 2004 Sea Ray does not have wood stringers I believe they are composite and ‘glued’ to the fiberglass hull
The only thing remotely resembling wood and maybe composite is well is a square piece around the motor key hole in the transom. My boat has Sponsons stick out to support the swim platform on either side of the transom so there is only a very small flat area that resembles a traditional wooden lay up transom around the keyhole
Those maintenance parts are comoletely unrelated ro SeaRay. Thats all motor ratedThank you for the info! That will go along way. How is the maintenance on the searay. Do you have to replace the gimbal bearings, manifold or any other parts often? I went to look at one a few days ago and the guy told me every 2 years he replacing the bearings and manifold.
Don't believe everything you heard.Gotcha, should I stay away from wood stringers on the ocean. I heard the saltwater rots them out very quickly.
You really should get some insulating rubber boots over those positive terminals.Here are a couple of pictures of the engine bay of a 2004 Sea Ray 225 Weekender . . . The structural areas (stringer, battery tray, etc) look to have laid-up fiberglass based on the texture . . .
So it would be fair to say it is not a molded fiberglass stringer grid (which would be quite smooth in appearance).
As for salt vs. fresh water. Wood cored boats tend to rot quicker in Fresh water vs. salt. Corrosion on the metal parts are a bigger issue when running in salt. Either is manageable with the corresponding maintenance.
Wood stringers are fine. They will last near forever if properly encapsulated in fiberglass. The problems happen when people drill into them and do not caulk or epoxy the holes when they drive screws in. If you are concerned about wood stringers, or wood coring material of any type, is to either hire a surveyor or simply buy a good moisture meter that is meant for cored FRP boats and see what kind of moisture meter readings you get, as well as percussion testing the stringers where accessible.Gotcha, should I stay away from wood stringers on the ocean. I heard the saltwater rots them out very quickly.
