Re: Hull repair
First of all, I hope everyone is OK...
The reason I said the repairs seemed to go further in is going by what I saw in the picture, where the Pink/Blue areas seem to have some damage...
It is hard to tell from this distance if those were just surface scrapes from the accident, or cracks...
OK, if you intend to use the tow eye, the best way to make a solid repair is going to require that the two halves be separated...That explanation will wait for your decision...
If all you want is a quick cosmetic repair, that can be done by removing any loose glass strands, grinding a taper out and away from the damaged area, grinding a slight taper into the broken off piece, mixing up some thickened resin to use as a glue...glue the broken piece back in place with the thickened resin, add a few little torn pieces of CSM [chopped strand mat] to fill and build the tapered areas and add a little strength, then finish fairing it in with a little more thickened resin...the last thing would be to get some gel coat repair compound and get as close a color match to the surrounding area as possible...sand, buff and polish...Remember, this is a cosmetic repair and may fail if you use the tow eye...
Also, some of the techniques described for this cosmetic repair will also be used in the more involved structural repair...
Let us know which direction you want to go, and ask any questions you may have...
