Hull polish or wetsand questions?
rothfm
Ensign
Been looking...there is just way to much info, and opinions.
Looking to see if someone has a laymans 1,2,3 for my situation thats proven and wont overwhelm me.
Have a 1986 Tiara Pursuit with twin v6's and hardtop. Ive spend 5-6 years doing many improvements and Maint.
My hull needs attention..dont want to make a giant project of it. It has some shine, but also not. Years ago someone used a hi speed buffer with heavy cutter and i believe that left alot of swirls and a "mottled" look, some shine some dull.
Ive tried mny products, 3m polishers, cutters etc etc...same results. I would accept wetsanding steps and multi step polishing if thats the way to go.
Again, so many methods and process out there....I need a simple breakdown of how to do this, with products. Something I can do with basic equipment, myself without reading a 1000 page manual and spending 5k.
My Harbor Frieght has some interseting pads. Papers and compounds.
Any thoughts that fits this?
Assuming it's gell and not paint
Start sanding with 600, go up to 800, then 1000. Then Aquabuff 1000, then Aquabuff 2000, followed by finesse it
bakerjw
Scott is correct. Go look at Joe's videos on YouTube under fishbumptv. He has some fantastic DIY videos. They are TOP QUALITY too!
post pics of the hull and the issues you are seeing.
you can get teh polisher and pads at HF, I would not get any papers or compounds there. you can get the rest off of Bezos's mega site.
if starting with nothing, you will probably spend $300-400 on polisher/pads/paper/compounds/wax/etc
for hand sanding, i am using either 6" DA discs and a 3M rubber pad or sheets of wet/dry paper and the same 3M rubber pad. long strokes, and lots and lots and lots of water. if you dont have water running down your arm, you dont have enough water. you are also only gliding this across the surface. you do NOT want to use alot of force. you will get stripes where your fingers press if you do
I use a variable speed general junk (AKA harbor freight) polisher. you are only running it at 1400 RPM for the aquabuff, about 1600 RPM for the finesse it and about 1700 for wheel buffing. you must change pads every time
Harbor freight no longer caries the chicago electric programmable variable speed buffer. so without the readout, remember, it has to be slower than you think.
they have this one that has 8 settings. I know nothing about it.
use the wool pads for the aquabuff, the waffle pads for the finesse it and the foam polish pad for the application of the wax of your choice
clean and change the pads often. you should be running the cleaning spur over the wool pad about once every 10 minutes.
i then soak them in the laundry sink, wash them by hand to remove most of the grit, then toss them into the laundry for the next time I need them.
you will wear the pads out, so make sure to have a few on hand. I have even had a new pad break apart and go flinging across the garage.
MikeSchinlaub
Bar ligh of some sort will be a tremendous help too.
Something like this. Hold it so that you can see the reflection of the flashlight and it will help you see the scratches. A spot light just doesn't show enough for me.
It will take some time, and gel takes a bit of pressure to really buff the sanding scratches out. Less once you move to polish.
bakerjw
For polishing compounds, look at Fiberglasswarehouse.com. Use code fishbumptv for a discount.
Or Merrittsupply. They may have some too.
rothfm
Ensign
Thanks Scott..have been on here in quite awhile-you have helped me in the past..
Just what I was looking for a 1,2,3 method..i will research yhe youtube recommended and supplys. Will take a few pucs tomorrow with a light a light & post up.
Im now wondering if a proper DA, with proper compounds may even it out...I used generic OTC stuff before by hand. It is smooth and does have some shine.
Thanks
You can use a DA for sanding, but I wouldn't use it for polishing
Grub54891
A buffer or even a sander with adjustable speed is helpful. I prefer to use lower speed when doing something like this. I did get a speed adjustable thing that I can plug my sanders and buffers into and it works well. I did that so I didn’t have to get all new equipment.
DeepCMark58A
Is the hull stained or dull? I would suggest using toilet bowl cleaner before you take the next step.
Luray Lou
I had never done this before and I went with the Harbor Freight buffer shown above in another comment, two medium cut FOAM pads and a bottle of Skwol. And a lot of microfiber towels. It turned out great, I think. The picture is buffed versus existing. I know it looks like dried compound, but that’s how chalky it was.
