Hull number missing
1980 Bluefin 14' aluminum boat. Hull number plate not on transom. Is there another number anywhere on the boat?
hull number should be stamped into the boat, starboard aft corner
Welcome Aboard,... If the number ain't where it belongs, it's gone,....
Do ya have the paper work for the hull,..??
If so, the hull number is on the paper work, so get a stamp set, 'n put the number on the transom, upper starboard corner,....
GA_Boater
You can even use an engraver. The point is to have a permanent HIN on the hull in the correct place. How it's done is unimportant.
