I am going to build a hull-mounted heat exchanger on one of my boats that will be used in shallow water. The engine is a small block 350ci Chevy powering a jet drive. The original setup used raw water piped from the jet pump for engine cooling. As the boat is now used in brackish/Salt water I want to change the cooling to a closed system and use a hull mounted heat exchanger. As the engine going in is a late model Vortec with thin wall casting around the some of the water jacket areas, raw water-cooling is not an option that I want to use.<br /><br />I have two pieces of 8 foot long Stainless Steel pipe/thick walled tubing, I.D.=2.200" & O.D.=2.500". (This pipe was salvaged from an Ammonium Nitrate system so it is weld able and highly corrosive resistant).<br /><br />Does anyone know how to determine how much surface area/feet or whatever I would need?
