Re: Hull damage, How major is this?
Hi and welcome dlambunion,
The damage you show in the pic should be a fairly simple fix and the least of your worries...
The age of the boat and the fact that it has probably been stored out under the stars for a few seasons??? is where your main concern should lie...let me explain...
If the baot has sat out in the elements for any length of time and has never been restored from the bottom up, you are most like looking at doing so, if you want to keep and use this boat for the foreseeable future...
Besides needing the most expensive part, an outboard, you are more than likely looking at doing the transom, stringers and deck...
You see, a free boat is
never free...
You need to check very carefully by doing some invasive surgery, the actual condition of the previously mentioned items...the transom, stringers and deck...
You need to take core samples of all of them by drilling into them at the lowest and farthest back areas you can get to, and determine how much rot has taken place, this usually involves the removal of some or all of the deck, which by the way should have NO, zero, absolutely none, soft areas...if when drilling into the structural members, you find nice dry, light colored wood shavings...then you hit the jackpot and can seal up the holes with some 5200 and move on...
If, however, they come out dark, wet and mushy...well then its time to make the ultimate decision...to restore or not to restore...
Whatever you decide is the best course of action, the members here will be more than happy to guide you through whatever needs doing...
Best of luck and Safe Boating!
GT1M
