First off the boat is a 1972 16' Glastron v163. I love the boat and with the help from others I gained the confidence to restore the boat. (was on the edge of getting rid of it but after getting the motor to run as good as it does I want to keep the boat.)(75 115 Evinrude) I have a few concerns about some areas of the boat before I dive into replacing the deck. I know the transom has been repaired. I dont know much about boats so Im not sure if this is a common way to repair it or not. Please keep in mind that this is a low as possible budget restoration and If i can save money I'm going to do it. I pulled the boat from TX to CO and the motor bounced on some good cracks in the road and it didnt phase the transom but I still want some more input. Ill try to describe these pics as good as possible. FYI Glastron max motor size for the V163 is 115hp.
Below are pics of the transom looks like steel plates and silicone? Is this normal? I tried to provide as many pics as possible so you can have a good understanding of what I'm looking at. The boat comes from the desert so rot is not something Im worried about. I believe the steel plates are because the original motor that came with the boat was a 72 evinrude 125hp larger than the factory recommendation. I traded a guy for his 115 and a little cash and bolted it on and runs great.
