jacknbella
- Aug 8, 2008
- 251
Just repacked the bearings for the 1st time but they are still running a little warm compared to normal. Don't have bearing buddies yet but the trailer does have "turbo lube hubs", meaning, they are bathed in 50w oil to supplement cooling (although, the hub wouldn't take much oil). I followed the directions to a "T" but wasn't entirely sure how much grease to add after repacking the bearings. Should I simply pack the hub with as much grease as possible, similar to what Bearing Buddies do?
Also, I didn't replace the inner seals either. I was able to use my fingers to pack the inner bearings, albeit, probably not as good as the "palm" method. Should I go back and just replace the seals anyway and pack the bearings the "right" way?
