FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Unless you have some sort of odd set-up, You have to pop the bearing cap, then remove the cotter pin and nut that hold the bearings in. After that, the hub and bearings should slide right off the axle.
I found no cotter pin. So I removed all the grease from around the nut and found a tab. bent tab and removed everything. Tab is on a spacer behind the nut. Yes I have flanges. Have the brakes on. Just need to wire it all up. Thanks guys
