hp rating for 16ft starcrafts
Bob_VT
Re: hp rating for 16ft starcrafts
It varied depending on model and year.
Which model/what year is it?
ezmobee
Yep, depends on what model you have. Mine is rated at 85.
sublimebass
i have no idea...i can't find any vin or i.d plate anywhere..how do you go about finding out the year?it's a 16ft closed bow it has one transom brace(i've seen other starcrafts with 2)and it's red (which i think is from factory,i had to strip the back and it's the only paint there)
ezmobee
How's about a picture. Does it look similar to mine?
Rickairmedic
sublime can you get us some pictures of areas like the dash that might help us with the year . I have a 1970 Jupiter V 16' and the plate is riveted to the side right near the dash . I know mine was rated for a max of 85 Horse with outboard and 60 horse with an I/O setup . Bob claims mine should get up over 40 MPH with the 80 horse merc hangin off it :D.
Rick
Rickairmedic
EZ none of ours looks like yours :D That windshield is sweet . Any chance the ebay auction you got it off of said what it came off of :D.
Rick
Rickairmedic
sublime is the bottom of the boat red and the top white . I know the 1974 Brochure shows the 16' Holiday in those colors .
Rick
ezmobee
Rick
I think it actually did but I don't exactly remember. I believe it was a Larson. The best part about it is that the connection between the front and sides is rounded and allowed for a good amount of movement allowing me to bow the windshield out to accommodate the curvature of the bow. I couldn't be happier with how it turned out. I can even still open the center if I want to.
Rickairmedic
EZ either way that windshield makes your boat . The way its laid back makes the boat look like its flying low even just sittin there at the shore :D.
Rick
Rickairmedic
Sublime I'll quit droolin over EZ's boat for a second :D. Every brochure I have looked at from 1962 through 1977 shows a max of 85HP on the 16' closed bow boats with an outboard and a max of 60 HP with an I/O setup.
Rick
Rail Meat
Mine is a 79' Super Sport 16 with a max of 85hp.
Has an 85hp johnson V4.
42 mph GPS.
ddrieck
Mine is a 1978 Starcraft Super Sport 16'
Max hp: 85
1976 85hp Johnson V-4
