HP and displacement
JB
Re: HP and displacement
You are right, Tee Boy. I tried to simplify it too far.<br /><br />Forktail explains it better than all the rest of us combined. :)
tee-boy
"And theoretically, an outboard producing 10 ftlbs of Torque at 5000 RPM will produce the same HP (WORK) as an outboard making 5000 ftlbs of Torque at 10 RPM. Work is Work, even though in some cases it is obtained by using more Torque."<br /><br />The above is technically correct. However, the 10ft lbs torque engine could never push the same load as the 5000ft lbs torque engine at the same horsepower. Example: A 300 hp Case IH tractor can always pull a heavier load than a 300 hp Chevy truck. However, they can both produce the same amount of work. Another example: A 250lb man can lift a maximum of 250 lbs and a 150lb boy could lift a maximum of 150lb. However they can do the same amount of work if the boy can lift 1.67 times the number of boxes compared to the man in the same amount of time.<br /><br />Hopefully Josip has a little more appreciation for us now!
JB
Yup. That's why I said peak HP ratings are almost meaningless.
Terry H
So...did Boater Mikey ever get his answer? :D
JB
More than he ever dreamed. :D
Forktail
Ensign
In a given amount of time, it would push the same exact amount, because the 10 ftlb torque engine does it 500 times faster. <br /><br />Work is work, whether it is obtained by moving large loads very slowly, or small loads very quickly. :) <br /><br />The trick is to get the highest amount of torque at the highest rpm, over the widest RPM range. This is why diesels, especially modern high revving diesels, can do more work. Unlike gasoline engines, they produce lots of torque over a wide RPM range. They hold their peak torque a long time. And now the modern diesels do it at high rpm too.
tee-boy
Forktail, You are basically agreeing with what I said. No further comment.
Hooty
I use ta know all that stuff.<br /><br />c/6<br />Hooty
