How WOT why ?
andrewkafp
I notice by reading through most posts, that most boaters want to run their boats at WOT or flat out. When they can't get 5,500 RPM out of their engines, they tend to panic and look for ways to get that lttle extra power and speed. Maybe I'm missing something, but I like to go slow and soak up the scenery. I will probably never know what my motor revs to, as the boat is for a relaxing day out on calm water for the purpose of fishing and relaxing. Is this just a power thing or am I just way off the mark when it comes to what to expect from boating? :confused:
JasonJ
Re: How WOT why ?
Some people like to know they are getting every bit of power out of their engines. For people who water ski, it is nice to know you have all your juice when trying to pull Big Uncle Bubba, for bass fishermen, they want to get to the fishin' hole first, for speed freaks they just want to go fast. Me, I live and boat on a large lake that can turn ugly quick, and while I usually cruise at 22 mph@3200 rpms for max fuel economy and the fact that I am never in a hurry, I like to know that I can get back to my dock if things get spanky out there on the water. Lastly, if you have the boat set up and propped right, you get your max rpms, and you know the engine is not going to ever be over-revved or bogged down. Its just good for the engine....
ZmOz
Re: How WOT why ?
The people worried about their RPMs (me included) are owners of things called SPEED boats. They call them that because the owners take great joy in going as fast as their motor can take them. ;)
andrewkafp
Re: How WOT why ?
It's not the SPEED boat owners that I am curous about. It's the normal 50,60,80 HP Outboard owners who have a desire to get more out of a relatively small engine.And the post is not an attack. Maybe running a 2 stroke fast is healthier for the motor than running slow ??<br />Hence.. the question.
ZmOz
Re: How WOT why ?
Yes, it is better for them. Helps clean out all the crap that builds up in there. Also if at WOT you are under the rated RPMs of your motor you need to get a new prop or you will soon need a new motor.
Ralph 123
Re: How WOT why ?
It is human nature to optimize and search for perfection. Part of the fun of owning a boat it getting it to run at peak performance.
roscoe
Re: How WOT why ?
If you are referring to all the WOT and rpm questions, maybe this will help.<br /><br />When running your engine at WOT, if it is reaching but not exceeding the recommended rpm range, the current set up is acceptable. By setup, I mean engine performance, prop, engine height, boat weight, etc.<br /><br />WOT is used as a measure of how the whole package is working. If your engine is functioning properly, but not reaching recommended rpm, then something is putting too much stress or resistance on the engine. It could be a prop with too high a pitch. It could be no spark on one cylinder.<br /><br />This is how you can zero in on the correct pitch prop to use.<br /><br />If your WOT rpm have been in recommended range, but now they have dropped 1000 rpm, you know to look somewhere other than the prop, perhaps an ignition failure, a carb problem, or 500 lbs of water in the bilge.<br /><br />2 stroke engines like to run at high rpm. You could run at WOT all day, or till you ran out of fuel and snacks. But best fuel enconomy is usually somewhere between 3000 and 4500 rpm, depending on the engine. <br /><br />Maybe I should say that 2 strokes run better when the resistance or load on the engine is limited to the point, that recommended rpm's can still be achieved at WOT. Any more load than that would "lug" the engine. Any less load than that could over rev the engine. <br /><br />The engine operates best when the load matches the engine. Your setup is how you match the load to the engine. On a car, you have a transmission that does this. <br /><br />But yes, there are lots of boaters that just like to go fast.
andrewkafp
Re: How WOT why ?
"It is human nature to optimize and search for perfection. Part of the fun of owning a boat it getting it to run at peak performance."<br /><br />2 x 350 Chevs may be going a bit overboard though...<br /> :D :D :D
GodsBeast
Re: How WOT why ?
Unicorn, I am Man enough to admit it, I'm going through a Mid Life Crisis. I get a kick out of the looks I get when I pass or keep up with a Ski rig in my 25' Party Barge! :p I'll grow up someday, till then I can claim I'm just young and dumb. I figure I can claim I'm young as long as I tag dumb along with it :D . Once I grow up, I guess I will get a Party Cruiser (Houseboat). Picture this, Walls and Roof, with Air Conditioner, sippin a Margarita, watching TV, with the window, slid open just far enough to stick a fishin pole out of. Then I guess I can claim, I've grown up.<br /><br />2 350's you devil, oh,,,,and Unicorn,,,, didn't I see a pic you posted on another thread of a nice looking rig with 3, count them, 3 big outboards on it? Now that thing aught to fly! If that is your boat on the back of that 18 wheeler trailer, I know those 3 motors are not for a slow Midnight cruise ;) Oh did I mention, nice looking boat!<br /><br />GodsBeast
andrewkafp
Re: How WOT why ?
Nah... not me.. I'm just a li'l ol slowboat driver. The "2 x 350's" was a cheapshot at Ralph.<br />And the 3 OB's well thems is just wishful thinkin'.
GodsBeast
Re: How WOT why ?
Oh OK, Unicorn, I See, so your a grown up! ;) <br /><br />I'll shut up now, caus us chillen are suposed to be seen and not heard! :D :D :D
mattttt25
Re: How WOT why ?
most of us on these boards that question wot and rpm's could care less about cruising at that speed. the simple fact is we want our engine to last. if you run with the wrong set-up, you're over taxing your engine and problems will come. rpm's at wot is just one set point all boaters should check. i suggest you do the same.
Sea Mitch
Re: How WOT why ?
This thread was great! I learn sooo much from this board. I thought that the more you ran your 2 stroke at WOT the faster you wore it out. I've never taken to WOT for fear of blowing the engine, kind of like redlining my car. This weekend I'm gonna try it out... I hope it works! It's a '93 rebuilt Yam 250.
Luna Sea
Re: How WOT why ?
Interesting post, my Evinrude's history in a nutshell. :confused: Girlfriend keeps telling me "don't touch nuttin till the seasons over". I read somewhere, maybe on here, that it was recommended 5 minutes WOT for every hours use at low speeds. Probably to clean the system out???Also, as in my case, problems go from bad to worse......
Ralph 123
Re: How WOT why ?
Luna,<br /><br />You have a very smart girlfriend... but tinkering is part of the fun IMHO.<br /><br />The more you tinker the safer you are. Sound crazy? Well, the more you know about your boat the better you become at spotting problems before the happen and fixing things underway.<br /><br />As for the twin 350s, I have no excuse. I sort of backed into this boat and then it became an obsession.
mattttt25
Re: How WOT why ?
first boat- don't take my post as meaning you should run at wot all the time. it should be used as a set point to check your set up. no other way to see if you are turning per manufacturer's recommendation (for me it's 5000-5500). but i agree, running at wot has to wear the engine faster than keeping her at a 3500 cruise. enjoy-
ED21
Master Chief Petty Officer
Re: How WOT why ?
What is the best way to rig a temporary tach on a 40 hp tiller model 1989 johnson to check out setup. The boat is a 16 alum & has no place to permanently mount a tach & I really don't want one. WOT doesn't have quite the smooth sound & feel as nearly wide open & I wonder if it is overreving.
andrewkafp
Re: How WOT why ?
Ahh well<br /><br />Trust the 'ol Unicorn to mix up a bit of muddy water in the forums.. :D :D :D <br />But if you carefully read the initial post, it is not a criticism of people who go fast..<br />I have a slow vessel, and have no interest in speed, but as has been pointed out here, an OB is not like the family car. It's more like a chainsaw, which simply does not work at low speed, and needs revs to cut wood... and to stay clean.<br /><br />BTW Ed.. No offence, but you'll most likely get more feedback if you raise your Tach question in a new post with a new subject. Or it will just get buried in the banter. ;)
