How warm does it have to be for resin?
Plainsman
What is the coolest temp I can use epoxy resin and glass and get good setup?
hrzracr23
Re: How warm does it have to be for resin?
good question I was wondering that myself
Boomyal
Probably 70+ degrees. But depending on the nature of the project there are things you can do to get the heat up. Space heaters under boat covers are one example.
klos
I've heard 75 to 85 temp range depending on the epoxie.
Tail_Gunner
Really just mix a pot of quick west systems in 40 degree heat it will cure in 15 mins. with that in mind , how can you say such thing's ,Boomyal or kloss not a challenge im really just wondering?
Bob_VT
Epoxy tends to generate it's own heat..... 70+ is the optimum temp. Make sure it starts out that way by keeping it in a 70 degree area before and during the mix.
Covering the area with a bit of heat will help. ..... just don't have a flash fire!
andy6374
You could use polyester or vinylester resin and forget about the temps (for the most part).
Plainsman
Thanks guys!!
I just want to put some glass down on the floor to the hull. However put the floor in did not do this.
