how to
smkjel221
Does any one know how to put the 1979 Chrysler 115 in neutral manuley?
Frank Acampora
Remove the cover. On the distributor or ignition side there will be two control cables with quick-connect fittings. The top one is the shift cable. Remove the quick-connect from the ball end. Now, push the shift lever forward or backward until the cam depresses the white button on the brown neutral interlock switch. This will be neutral.
