how to wire a kill switch in
smallboatlover
Banned
as of right now i dont have a kill switch and i am planning on rewiring the boat soon and tips on how to put a kill switch in the boat
joed
Re: how to wire a kill switch in
Check your ignition switch. If it is normally open when running then wire the kill switch in parallel to be closed when tripped. If it is normally closed when running then wire the kill switch in series to be open when tripped. Be sure to wire to the ignition wire and not the starter wire.
Don S
a outboard motor 50 hp 1985
Does your outboard motor have a manufacturer? With that, you may even get information as to wire colors and how to hook one up.
seabob4
OMCs (Johnson/Evinrude) shut down the motor by grounding the coil. On your ign switch, pull a jumper from your "run" circuit to the center terminal of an on/off switch. From the ground on your ign switch, pull a jumper and terminate to the bottom terminal on the on/off switch. Flip the switch, and you'll kill the motor...
