how to wire a johnson tach
jaybrown
Banned
So i bought a new boat to me it runs great 21 fot hydrostrram voager but the tach isnt working. The tach is there but the guy i bought it off of said he blew up the merc tht was on it and put a johnson 175 v6 on it, where would i run the wires to for the tach to work? motor is 1989 i dont have the serial number with me right now but can get it by the weekend
F_R
Honorary Supreme Mariner
Don't know what kind of tach you have, but the typical modern tach gets its signal from the motor's alternator. There should be a grey wire in the remote control for that purpose. Other wires are a ground wire, and probably a 12V power wire which comes from the ignition switch. The control may have all this handy at a plug. Lastly would be an illumination wire from the boat's running lights.
Assuming the tach has a switch, set it on 6 for 6 pulses (may be 12 for 12 poles--same thing)
jaybrown
Banned
Ok thank you where is the alternator located in this motor its new to me? I was just thinking of running new wires, one for+ one for- and one for the signal but not sure where to run the signal wire to? i will take a look at the controlls
jaybrown
Banned
I have a wire diagrahm is it the grey wire from the regulator the signal for the tach?
Silvertip
Yes. You can use the same POS and NEG wires that are currently on the existing tach. Or simply jumper from the POS and NEG terminals on any other gauge.
