How to trailer your boat/outboard safely
Bass_boy7
hello everyone im about to embark on my first road trip with my boat and I was wondering whats the best way to pull it behind my truck with the outboard motor down or up? or how should it be pulled I am not sure on how to do it so if anyone could let me know that would be most appretiated.
KM2
Re: How to trailer your boat/outboard safely
Down is good if the motor has no chance of contacting the ground.
CATransplant
For future reference, you should always describe your boat, outboard and the rest of your set up when you start a thread like this. I went back and looked at your other posts to figure out what your rig was like, but most folks won't take the time.
If this is that 14' aluminum boat and 25hp outboard, don't tow that rig with the motor down. You'll smack the cement coming out of some driveway somewhere, I guarantee. Also, don't tow it with the motor in the raised position, held just with whatever your model has to hold it raised. It will flex the heck out of your aluminum boat's transom. Aluminum doesn't like that at all. Eventually the metal will fatigue and crack. Not a good thing.
What you need is a $25 transom saver. There are two types. One has the bottom fit over the rear roller of your trailer. The other has a little bracket that bolts to the trailer frame, with a pin that secures the transom saver's bottom end.
On the other end is a V-shaped bracket that fits the outboard, holding it up and braced to the trailer. No flex. No bouncing. No broken parts on the outboard.
If you have a roller right at the back of the boat when it's on the trailer, get the first kind. If your boat overhangs the back of the trailer, get the second. Pay no attention to the thing about only using these with outboards with tilt and trim. Your 25 won't overstress it at all.
Also, make sure the stern of the boat is securely tied down to the trailer. If you're using a gunwale strap across the boat, it's likely to loosen as you travel. Add another one, or add straps from the stern handles on your boat to the trailer. You don't want bouncing or shifting.
All of this applies if you're going on a long trip. If you're just going five miles to the local lake, don't stress about it.
Bass_boy7
yes I am heading about 2.5 hrs away from home this weeknd for the season opener for walleye here in ontario its just a small tourny so thanks for advice I am going to have to look for a transome saver
CATransplant
Good move. Just go to any marine supply place. They'll have 'em. Buy the cheap one. You're not supporting a 400 lb. outboard. Your 25 is a lightweight.
fishrdan
Yes, I would add a support for the lower unit. I kept an eye on my outboard while driving and hitting bumps, it was flying all over the place and even raising almost all the way up to where it might lock into place in the raised position :eek:
I'm cheap and made one for my 7.5HP,,, 2" steel tube (old torchier lamp part), rubber hose, carpet and a 4" bolt for a removable pin, in an hour I had one made for about $0.00. Center cut tube back 4-5", flare end, cover lower unit contact areas with rubber hose and carpet, drill hole in trailer frame and tube for removable pin,,, viola!
a70eliminator
Another tip for ya, Don't hook up your fuel line till your there. My outboard flooded bigtime one day after a 2hr trip down the highway with fuel line hooked up. The result of the motor being tipped back along with the tank vent being closed which built enough pressure to push the past the carb needle.
DRIFTER_016
Definately get a transom saver, well woth the money.
I would also use a pair of transom tie downs so the back of the boat doesn't shift when going over bumps.
Silvertip
Honorary Supreme Mariner
Make sure your boat is secured (as in tied down) using tie down straps at the back and that the winch strap passes under the bow stop, not over it. A safety chain is also required up front. Before you pull out, make sure your lights work and that the tires are properly inflated and that the wheel bearings have been serviced.
Bass_boy7
well I took the trip, we came into 4th place at the tournmant and the boat faired well on the hwy trip, I had the tie down straps on the boat etc all went well, I unfortunately didn't get my hands on a transome saver for this trip but I will for sure the next trip. I drove with the motor down and cringed as I went over bumps but we made it alive and well haha.
Silvertip
Winch strap or rope goes under the bow roller, not over it. Safety chain is also recommended to keep the boat on the trailer thus preventing it from being launched onto the back of your tow vehicle in a panic stop or crash.
jtexas
Note that most transom savers specify motors "equipped with power tilt only" or similar. If you don't have power tilt, you'll have to tie that motor down securely or else it'll just bounce off. I don't think a bungee will do the trick.
