92excel
- Oct 6, 2008
- 477
Is there a way to test the potentiometer (trim sender) other then getting a new one and swapping them? Or how to eliminate it for testing purposes?
The Drive will go up and down
My red light on my volvo trim indicator is coming on way before the drive is all the way up (Its reading 7) and is stopping the drive there.. I have checked all the wiring, fuses and relays.. all seem to be fine. If you manually raise and lower the steering helmet the indicator does adjust the number being displayed depending on its position. so all seems to be fine minus it thinking it is already all the way up.
I have the the square digital indicator and the following pump:
