FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
its testable with an ohm meter however I would prefer using a DVM with a DVA attacment or a peak reading meter and check for output voltage rather than resistance.
then your pretty much stuck with resistance tests. not as reliable or efficient as peak voltage output tests.
what are we testing the stator on and why?
I am trying to diagnose a tachometer that is not working right and the Yamaha factory tech told me that it was a problem with the stator. I had been reading in this site and thought it was the rectifier but the tech said that was not the problem; that it was the stator that was the problem. The engine runs like a top but the tach registers innacurate values; about 2700 at WOT and 1200 at idle but the engine is not ideling that fast. Basically tach registers 1/2 at WOT and about double at idle. The tach increases and decreases smoothly in between and not erratic but clearly not accurate. The tach setting are set correctly and I have also tried on a brand new tach with the same results.
The battery also charges but I did 'catch' the volt meter at over 16v on one occasion but not since.
I feel like I have hijacked this thread. Should I repost?
