How to tell the age of a sportcraft 1900 sprint
Hi there im trying to find out the age off my sportcraft 1900 sprint i just got it a week ago iv had a few boats in the past mostly bayliners which i know the age is in the number on the rear right of the boat but i cant find anything on the sportcraft ????????????????? Anybody any idea ?
Re: How to tell the age of a sportcraft 1900 sprint
The boat is white with blue strip tho it and has sp leg in white if this helps
NYBo
Keep looking on the transom for the HIN.
Iv had a realy good look and there rrealy seems to be nothing there !!!!
Ayuh,.... If there's No numbers, it's atleast pre-73, 'n there no way to know any other way....
Post a picture, maybe somebody'll recognize it...
Ill post a pic tomorow i deffy dont think its that old !!!! It looks early 90s maybe late 80s
Are you in a title state? If so, the previous owner should have provided the title for the boat, engine and trailer if required.
Im in stirling in scotland lochlomond is 20 mins away and we dont need or have any paper work for boats here cheers anyway
oops!
if it looks like 90's the hin must be there...
even if the boat was re built and the transom re gellcoated....it still must be there by law.
Don S
Is it a boat from the US?
All i know off the boat is its a sportcraft . Inside it has 1900 sprint on the dash i know its very little to go on but its all iv got !!
JoLin
The 3 boats I've owned all had the VIN etched into the upper starboard area of the transom. If you can't see it (maybe that blue stripe was a repaint?) run your fingers over that area. You should be able to feel it.
Good luck!
retriever
I had a 1989 sprint 1900CC that looked very similar. The hull number was located just under the rub rail on the transom. I can't remember for the life of me which side but I believe the right side. Mine had a flat panel windshield and I remember the 1990 model had the curved windshield. So you could assume it is at least that new. You can also try matching up the age of the motor and outdrive since it appears to be original to the boat (mine was an AQ131c mated to an SP-CD Volvo outdrive). Hope that helps and enjoy the boat - if it weren't for us changing boating styles we would still be cruising around in our Sportcraft.
