How to tell if it's time to replace a prop
Natty Light
14 1/2 diameter
23 pitch
stainless steel
2002 Yamaha 150 VMAX 2 stroke
I recently ran aground a few times coming home at night. I was going very slow (less than 10 mph) due to low visibility so none of the impacts were abrupt. One of them was firm enough to stall the engine though. The next morning I ran the boat to make sure everything was ok. It ran great at high speed. At idle speed I thought I could feel a deep vibration that would come and go. I wasn't severe and perhaps I am just being paranoid because I am new to boating. If I would have damaged something would it be obvious? How can i check to make sure my prop and shaft are still in good shape?
steelespike
Re: How to tell if it's time to replace a prop
Did you look for damage. Pictures would help.
You could remove the prop and rotate the shaft near an indicator like a screw driver held close to the shaft to note any oscillation
Natty Light
Thank you for your reply.
I examined the prop and saw no sign of damage.
jkust
Put your spare prop on and run it for comparison.
