how to tell if engine is charging batteries?
junior1113
just bought 2 brand new decka marine batteries2 mos ago and the voltage was 12.61 on both now after 2 runs the voltage is at 12.06. just wondering the correct way to see if engines are charging. and if its not what is the cause thanks in advance p.s 1993 200 ocean pro
F_R
Honorary Supreme Mariner
Re: how to tell if engine is charging batteries?
Is that the voltage while running or not running? If while running, it isn't charging. I would assume your motor has a regulated charging system, so running voltage should be around 14.5 volts, assuming you aren't drawing out more juice than you are putting back in.
junior1113
will test with running and see what i got
One of the best ways is to put a dc fluke meter on the battery terminals. So we'll say you have 12 vdc . when you start the engine look at the voltage. increase rpm and if your 12 vdc is now increasing... tells you that it is charging the batteries. Now... are the batteries draining somehow.. corrosion, loose connections, just a thought.
junior1113
ran it to 4500 on hose hate to do but only for couple seconds was reading 13 volts i guess im good thanks guys
F_R
Just a couple of technical facts to ponder over: Electical current is described as the flow of electrons from atom to atom, in a circle (circuit). In the case of a battery, the electrons flow out of the negative terminal and return to the positive terminal when it is supplying power to a load. The guts of the battery are part of the circuit and the electrons are passing through it. (Yeah, I know, that theory is hard to grasp.) But anyhoo, when the battery is being charged, the electron flow is reversed through the battery---in the negative and out the positive. To make those electrons go through backwards, the charging supply voltage has to be greater than the battery voltage. THAT is why a battery under charge will show a higher voltage than one just sitting there, not being charged.
More to ponder: Without gettng into details, the battery voltage while under charge rises slowly as the battery takes on a charge. That is why it takes awhile to reach its max. Regulated charging systems limit the charge voltage to a design value. Unregulated charging systems just keep increasing till factors such as resistance eventually limit it.
