Solas sponsors the prop forum.
Do you have the prop size info Usually found under the prop nut?
At the top of the prop forum hover over boat parts and accessories click on propellers.
If you get us your boat info, motor info, and prop size and your wot rpm and gps speed we can help you get setup.
Solas 4 bld. 10 X 7 1113-100-07 8 spline $80. Found 6 props 3, 3 blade,2 4 bld, and a stainless.
Starting from the "boat parts and accessories" at the top of the forum.
Hover over the tab till it drops down click on props.
I was able to find that certain years 4 hp Merc 4 st and Tohatsu 4 hp 4st. seem to share props.
It appears the 8 3/8 X 6 No success with a brief search.
I have notified our programmers and they will work on a solution for this. For the time being, you should be able to access the propeller section from the Boat Parts and Accessories drop down. Let me know if you continue to have issues.
Still a bit confused. I did all that the first 25 times I tried to look up the correct prop, I touch on propellers and I get to the Solas page and from there I can only get a list of every prop made by Solas, no menu to show what actually fits the motor I'm looking up. It could be that I'm doing it from my iPad, I've always used my laptop before.
