How to set timing
al0311
Hi guys got my distributor in and got the motor running but I need to set the timing ?
Never done this before so I'm looking for a walk through on how to do it.
It's a 1990 4.3 thunderbolt IV ignition.
achris
More fish than mountain goat
Put a timing light on #1 spark plug lead. Warm the engine and have it at idle speed (650-700rpm). Point the timing light at the timing marks on the timing cover and front crank pulley. If it's not at 8BTDC, loosen the distributor clamp screw and rotate the distributor until it is. Tighten clamp screw. Shutdown engine and remove timing light. TB-IV doesn't have a 'base mode'. It's point and shoot.
al0311
Sweetttt thanks so much
