Re: How To Set Timing 97 5.7 Thunder Bolt V
Line up the 2 dots on the timing chain if your cover is off,or if its on align the tdc mark on the balancer,then install the distributor and make sure the rotor is pointing at the #1 spark plug wire.When you get it started hit it with a timing light and set it to spec.Just make sure its at TDC on the compression stroke.
